Driver side, car latch
The inside handle I believe something came undone cause it won’t catch to open. How do I remove panel (s) to see what the problem is and maybe re-attach to fix or replace?
Thanks.
Gino
This video looks like the ticket, you may want to start with the handle just to see if you can do it without removing the whole panel. Hopefully the outside latch still works.
http://video.search.yahoo.com/video/play;_ylt=A2KLqIBBhdhQYhoA6837w8QF;_ylu=X3oDMTBvZ3AycDJsBHNlYwNzcgRzbGsDdmlkBHZ0aWQDVjEzMA--?p=ford+fusion+remove+door+panel&vid=e4fc6f65e72d750ab184132e05d39444&l=&turl=http%3A%2F%2Fts4.mm.bing.net%2Fth%3Fid%3DV.4762801743790211%26pid%3D15.1&rurl=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DmNuQ5vpR3fE&tit=Removing+door+panel&c=0&sigr=11ah2sti6&fr=moz35
THANKS. UNDERSTAND COMPLETELY.
Gino
