Fuel pump fuse blows
removing auto shutdown relay
and fuel pump runs and no fuse blow
leaving auto shutdown in and fuel pump
relay out and fuel pump fuse blows
looking at wire diagram and removing
green/orange injectors, noise suppressor,
oxygen sensors,coil pack & generator
The green/orange wire still tests grounded.
wire diagram shows 0.47 micro farad capacitor…
Is this part of the generator/alternator?
looking at wire diagram simply removing
green/orange from a liernaior does this
disconnect capacitor from wire
(green/orange) Could this be a shorted
too ground?
Is capacitor part of generator?
Are you calling fuse #21 (20 Amp) the fuel pump fuse?. I’ll assume so. You’ve pinned down a short to the dark green/orange wire from the ASD relay to all the components it powers. Have you, actually disconnected the dk grn/o wire from the alternator, both oxygen sensors, the fuel injectors, ignition coil, and the engine computer, and the circuit still shows grounded? If you have, and the fuse #21 still blows, then the short has to be in the wire, or the capacitor, to ground. The capacitor is a noise suppressor for spurious electronic noise for the entire circuit. It, normally, only acts as a ground for higher frequencies (static), It’s not impossible that it has grounded the dc power.
