Disappearing dashboard during rainy weather
My 2000 Infiniti G20 has a problem only when it rains. The odometer, speedometer and temperate gauge all disappear or stop working when I drive in rainy weather. The gas gauge is the only thing that works. After the car dries out, they all work again. What could be causing this?
You got the English LUCUS addition.
I suspect you have a ground problem. Look for a wire connected to the instrument panel and check the connections at each end.
That sounds like a possibility. I will check it out.
