Some of the lights on my dash are out.All work but the gas gauge,rpm,radiator,speed, do not. You know,the four that are in the cirles on my dash. Any ideas?
Have you checked the fuses, otherwise you will want to ask the dealer or get an electrical schematic to find the series lights and which 1 it is.
I believe those that are not working are supplied through a voltage regulator. I would suspect the regulator.
