Dash Lights
I have 2007 Chrysler Sebring. The dash lights went out . I know where the fuse box is, but don’t know which fuse it is. The book doesn’t mention dash lights.
On some cars thatI have owned, the dssh lights and tail lights are on the same circuit. Check to see that your tail lights are working. If not, check this fuse.
One suspect when the dash lightws fail is the rheostat which dims these lights.
If your radio does not works, check fuse #7 (30 amps), otherwise, check fuse #14 (10 amps).
Are you sure they are just not dimmed?
Note: fuses are like the circuit breakers in your home. If they blow, it usually is an indication of a problem. Fuses do not just wear out.
