Crank windows
I’m thinking about a used Ford ClubWagon, '95 or older (no emmisions insp.req.) Can I replace doors w/power windows w/doors with crank windows?
E
Are you sure you want to?
So sure you wouldn’t believe it!
E
Sure/ the door doesn’t know whether it’s got elec. or man. windows
Yup. Just be sure you tie off the wiring so you don’t get any shorts to ground.
The doors must be in rough shape. Are you sure the rest of the vehicle is worth buying?
