Driver can put front passenger window up and down but the passenger can only put the window down. The rear driver’s side window won’t go up or down from the driver’s seat but will go down only from the local control not back up. Currently the motor is unmounted and propped up so it won’t snow inside the car.
Clearly, the passenger side switch is bad.
It’s also possible that the rear driver’s side switch is bad. A fault in the local door switch can stop the window from working from the driver’s door switch. Of course, it could be something else too.
