Patient: 2002 Ford Focus SE
Mileage: 140000
Symptoms: When turning right, especially at low speed while braking, it makes this rapid clicking noise, disappears once you let go of the brake.
In the past when it made this kind of noise, usually goes away after I made sure the brake pads clips are securely clipped around the caliper, but it’s not working this time. No noise while braking going forward or turning left. Seems to be worse at lower speed and any right turn can bring on the noise, does not have to be a full-lock turn.
So far what I’ve done: Made sure the brake pads clips are secured (horribly designed), lug nuts are torqued at correct spec, no obvious broken linkage, bar, arm, coil, or CV boots under quick inspection.
Could this be the CV joint? Ball joint? Bushings? Bearings?
