changing from celius to fahrentheit
check your owners manual. It will tell you how to change your system back and forth
thanks we looked over and over their is a screen that states to change units which we did, however it doesn’t change on the heat/ac/ screen near the buttons
triciamrie
triciamrie@aol.com
Hmm…unless it’s in another section (like if there’s a section specifically for those controls), you may want to run by the dealership one day to see if they can help you. Unfortunately I don’t own a car that is newer than 10 years old so I don’t own something with a touch screen!
You are still under warranty so the dealer should show you what settings to use. Also you should never put your email address on an open web site. Edit it out.
