Any instructions on this tells you to reach under the wheel well and open the access door and reach in and pull the bulb out but this is easier said than done . It is very hard to locate bulb and pull it out.Does anybody have any tips on this that could help? Thanks
This seems to be a periennial design screw-up with Chrysler. I have a 2004 Concord with a burned out passenger side front side marker. The manual says to reach under and pull the socket out. This is impossible with less than 1-inch of clearance. A dealer quoted me a $175 cost to replace the bulb. It seems that the fender liner needs to be removed. Needless to say, I continue to drive without a right side marker. Good luck.
