Changing a brake light ('95 Dodge Stratus)
Does anyone know how to change a brake light in a 95 Dodge Stratus? It’s my first attempt.
Thanks.
Very easy, open the trunk peal back the carpet by the tail lights, there is a few big plastic wing nuts, unscrew those nuts and the hole tail light assembly comes off the car. Replace the bulb with the assembly off the car
You do it from inside the trunk. Peel away rhe carpeting and paneling, if necessary. Grasp the light socket and give it a quarter counterclockwise twist to remove.
Edit,
don’t even have to peal back the carpet there are cutouts in the carpet that the wing nuts stick out.
