Hi Anyone
Any ideas on ceramic coatings. Why does it cost so much? Is it worth it? Can mere mortals apply the coating or do I need to spend 600plus bucks at a detailer
Are you unhappy with your current wax? I’d never pay that, I garage my cars and don’t worry about waxing them at all. They both look fine after 10 and 13 years.
Wax it once or twice a year and save yourself a lot of money . You could probably do the ceramic coating too but it might not come out quite as good as a detailer because they have all the power buffers and stuff to take it off . It is really just a fancy expensive wax .
Thanks. It just that im buying a corvette and people are pushing a ceramic finish.
… which gives them about a 95% profit margin, at your expense.
For real-deal ceramic coatings, most of the price is the prepwork that’s necessary. Before you ceramic coat a car, you need a full body paint correction done to it (otherwise the coating will protect the flaws in the paintwork). Even on most brand new cars this is necessary. The older the car usually the more extensive the paint correction needs to be. A proper professional paint correction can take a day or two and cost hundreds of dollars alone. Once that is complete the actual ceramic coating can begin. Most pro-detail shops will do at least two coats, usually three, and each coat has to cure for 12-24 hours before another coat can be applied. The car needs to be kept indoors while this is happening. The total curing time is about 2 weeks, but the car can get wet about 24 hours after the last coat. Just to be clear, this is not the miracle wax that dealers peddle in the finance office.
It’s an expensive, time-consuming process. But the results are impressive with a level of protection well above even high end sealants , still though, I would only have it done on a high end exotic or a totally restored classic with a concourse quality paint job. For me giving my car a proper detail (strip wash, clay bar, polish and a high quality sealant), twice a year is all you really need, assuming you keep up with the maintenance washes.
I agree with FoDaddy’s reply.
You’re getting a great finish with ceramic, but you’re paying for a labor intensive process.
There are lots of sites and videos describing the pros and cons of ceramic coatings. Here’s a good video to watch:
https://www.youtube.com/watch?v=k1oEKHCAABA
That video provides a good overview comparing ceramic vs other coatings. But more important, it helps to explain if you do get a ceramic coating, there’s an implied assumption on how you’ll take care of it.
Thanks everyone for your realistic info about ceramic finishes. As an experiment I bought a bottle of spray on ceramic ,approx 25 bucks, and I experimented on my13 year old Camry. The company is called ‘Torque’ . Yes, it’s a lot of work to get the car clean enough to to use the spray. The results are quite spectacular especially on the grill and headlight lens. I think it’s good for 6 mos to a year depending on the environment.
I think I’ll save my self the big bucks and if and when I ever get my corvette I’ll just use the spray from Torque.
Thanks for the good advice.
Sam
Glad it worked out for you. However, a pro-level ceramic coating doesn’t come in a spray bottle. It comes very small bottle/vials (1 oz or thereabouts) and will cost about $100-$200 per oz. The spray stuff contains some ceramic content, but it’s made to be accessible and easy to use apply. It’s not as effective a full-on, professional coating, but’s it’s much, much cheaper and much more forgiving to apply.
My 18 year old car I waxed maybe 2 times, got rear ended, finish looked fine, sure some rust bubbles here and there, at the bottom of the door panels. Got to clean the insides of those I guess. I applaud you that do so much more, but doubt the trade in value would have differed much.
That’s an excellent point. Put a finish on the car that costs a small fortune and brave the odds that it will survive all the craziness we all brave on the road. The monetary compensation we get from the insurance company will never cover the cost of beautification. On the other side is the pride of ownership. If it does get stolen or become a total loss the surviving pieces will look just great.
Last year I tried the Turtle Wax Hybrid Ceramic wax. Goes on like a normal wax. It is by far the longest lasting wax I’ve ever used. Easily 8-10 months plus. Even in our cold harsh winters.
Ceramic coatings can be worth the investment, but it really depends on your expectations, budget, and how you maintain your vehicle. The higher cost at a professional detailer usually covers more than just the coating itself. It includes thorough paint decontamination, surface preparation, paint correction if needed, professional-grade products, application time, and controlled curing. Proper preparation is particularly important because a coating can lock in existing swirl marks and paint defects rather than hide them.
You can absolutely apply many consumer-grade ceramic coatings yourself. Most DIY products are designed for enthusiasts, provided you carefully follow the manufacturer’s instructions and work in a clean, shaded environment. The key is to wash and decontaminate the paint properly, ensure the surface is completely dry, apply the coating evenly, and remove any high spots before it cures.
In terms of value, ceramic coatings can make washing easier, improve gloss, and provide resistance to certain environmental contaminants. However, they are not scratch-proof and do not eliminate the need for regular maintenance. If your paint is already in good condition and you are comfortable doing the preparation yourself, a DIY coating can be a cost-effective option. If the paint needs significant correction or you want professional application with a warranty, paying a detailer may make more sense.
My advice would be to start with a reputable DIY coating if you enjoy working on your car and are prepared to take your time. The quality of the preparation and application often matters just as much as the product you choose.
This is a discussion from 2021 and has been solved. Look to the right side of your screen and you can see when each post was made.
Old or not, the discussion is still valid. Id never done it before but so far i am quite happy with the dealer applied coating. Something like a three to five year warranty but the maintenance products are not cheap either.
I wrote the original question. But in the last 6 years I’ve used products from TorqueDetailers and had fairly good luck with them. I graduated to another product called redline ceramic
Which brings me to another question: If a container is opened and the cap is loose is the ceramic still good? Little loss and I got my money back
One thing I do which will help keep you alive is to wear googles, rubber gloves , and a good N95 mask. The spray chemicals used are very volatile. Besides who wants to breath fine glass particles. Your kidneys and lungs will thank you!
Sam
There is no way I am using something on my vehicle that requires that much protection.
No actual glass particles, there is silicon dioxide used in these coatings. Also, N95 offers no protection against volatile chemicals.
