Car wont start
i have a 1988 jeep wagoneer and it wont start it dosent make any noise when i turn the ignition and the lights or nothing wont come on can someone tell me if its the starter or what it is
[b]Check for good battery connections.
Tester[/b]
we already checked that
[b]Check the battery condition
Tester[/b]
its a brand new battery could it be the the positive cable it seems like nothing is getting any juice
[b]The vehicle is old enough where replacing the cable is not only cheap, but probably needs it if never done.
Tester[/b]
[b]Also check the negative cable for a good connection at both ends.
Tester[/b]
good it be the neutral switch
[b]No. The Park/neutral safety switch just prevents the starter from operating.
You have no power to anything. So think of it as, the battery’s still disconnected.
Tester[/b]
