I think I see a clear liquid agitating, about half-way up, but I’m not sure. Would a borescope help? Special lighting? I tried a flashlight.
Clean the glass off a little better and with the engine running shake the truck a little, you should see the level slosh around slightly.
Can’t tell that it is clean? I heard that tip about sloshing. Thanks.
Clean all of the glass, q-tip with glass cleaner.
Clean it completely then use a penlight up against the glass. Or remove the air cleaner housing and take it out into the sunlight.
There’s too much light scatter for me to see the liquid line. A polarizing filter on the camera might help reduce light scatter into the camera. I imagine you are using a cell phone camera and I’m not sure how much filtering is available. As others said, you need to clean the sight glass better. Maybe light scatter won’t be as large an issue then.
I don’t care but some readers might. What is that sight glass for?
That’s how you check the fuel level in the float bowl of the carb.
I came across this web page that you might find useful. I think it’s the same carb. that you have.
On the 3rd page it shows where the correct fuel level should be. also, there is a parts diagram.
Believe it or not I cleaned it as well as it can be cleaned. I wouldn’t ask for help without.
I tried that, but it seemed to make it harder to see, possibly because it decreased the contrast.
I’ve thought about that.
What with the hood blocking most of the light this is hard.
Would a borescope help, or some other aid?
You sent me that before. I read it.
The person who doesn’t know would probably want to know why that matters. If you don’t know what a sight glass is for you probably don’t know what a float bowl is.
A borescope may not help much here, as the trouble is glare and contrast rather than reaching the glass. I would shade the sight glass with your hand or a cloth and look from a low angle with the light behind you, which can make the fuel line stand out better. If you can see it, the level should sit about halfway up the glass when the engine is off.
I do know what a float bowl is. I also know why the level in the sight glass is of use. I just could not tell what the picture was trying to show. But their are many people who have never seen or even know about a sight glass on a carburetor.
I am looking forward to reading the advice those people have to offer.
It’s already as shaded as it can be, and only a low angle is possible. I agree that glare and contrast are significant problems. Perhaps if I got better-collimated light, maybe a laser. I haven’t used a borescope. I can get it right up against the sight glass, perhaps illuminate only the window, thus eliminate glare from the surrounding surfaces.
Yes, but they also don’t know about float bowls. It’s a not a big deal, but if you’re trying to help tyros understand the issue we’re discussing they’d need to know about both. I agree with @Nevada_545 that those people probably aren’t reading the thread.
Hence this statement-
There’s a chance the level is just above the dirt line, or whatever that is remaining on the glass and that’s why you cannot see it.
It sure looks like the wider parts of the glass in the aperture are still dirty. Maybe some light polishing compound or toothpaste on a Qtip will help clean it up…
@RandomTroll All you had to do was say you were having trouble reading the sight glass on your vehicles carburetor. Then the people who visit here will at least know what your problem is. If they want to know more than a web search can be made.
RandomTroll: the haze you’re fighting is more likely on the inside of that glass than the outside. That window sits exposed to fuel vapor, so varnish builds a film on the bowl side, and no amount of q-tip work on the outer face will bring the contrast back.
On most of these the window is a plug threaded into the bowl with the glass set into it. Unscrew it carefully (lean on it and the glass cracks in the brass), clean both faces with carb cleaner and a soft cloth, put a new fiber washer behind it if it had one, and snug it only.
If it is still unreadable after that, quit working the glass and measure the float level directly against the book spec with the carb top off. That gives you the real number the window is only supposed to approximate, and it tells you whether there is a mixture problem here at all before you spend more time on how to look at it.
