As I wrote before, I already tried with a penlight. I wondered if a borescope would illuminate even less, that I could put it up against the glass. I also don’t have to put my head down there with a borescope too. It’s already clean. The picture is poor.
I said that.
They could have done that to figure out what a sight glass is for.
Last time I looked it was $400. I don’t know I have to go that far yet.
Anyway to access it without taking it off? Say with a flexible tube to spray carb cleaner on it.
I know about that. I was hoping for a tip on reading the sight glass so I don’t have to.
Vapor would be above the fuel level only. That glass is opaque on both the top and bottom of the sight glass and the middle is clear. It looks like it was wiped with a cloth and only the middle got attention.
I specifically mentioned putting the penlight up against the glass. If the penlight you used couldn’t do that, then it wouldn’t provide the advantage mentioned.
If you have a borescope, great! That would be best. I bought one a couple years ago and it’s been a lifesaver for lots of things besides examining the inside of engine cylinders. Last time was to look into a wall cavity at home to see if I had clearance for an electrical box for the new TV. Only a small 3/8" hole is needed to feed it in there. It can adjust illumination and select from front or side camera. You can bend the head with a mechanical dial and it’s probably 3ft long…
With the engine warm and running, use a pair of needle nose pliers to pinch shut the rubber fuel line that feeds the fuel pump (or the line to the carb inlet, if accessible). You should see the fuel level drop if the level of the fuel is higher than the sight glass or if it’s lower than the sight glass, the engine will stall when the fuel runs out. When you release your pliers the inrush of fuel should create some turbulence or bubbles in the bowl, helping you see the level.
RandomTroll: yes, you can feed a length of tubing in through the bowl vent and spray at the inside of the glass. I wouldn’t. You are working blind on a small window set at an angle, so most of the solvent lands on the bowl wall and the float, and carb cleaner is a solvent, not a rinse. Soak the accelerator pump cup or a needle seat o-ring and you have traded a stain for a flat spot and a leak.
TwinTurbo has a fair point. If the haze stops in a straight line where a rag quit, that is on the outside, and a dab of polishing compound or plain toothpaste on a cloth will bring it back. Test it this way: light at a grazing angle across the face. Film on the surface scuffs under a fingernail; film on the bowl side does not.
asemaster’s pinch trick is the cheap way to get contrast without touching the glass. The turbulence on release draws a line you can actually see.
If it is still unreadable after that, the window has done its job and you are down to the plug or the float spec.
