we have replaced the master cylinder in the car and now we are having problems bleeding the clutch. Any suggestions?
Some clutch hydraulic systems can be a bear to bleed. Open the bleeder on the slave cylinder and see if it’ll gravity bleed. If that doesn’t work you may need to use a pressure bleeder like that used for brake systems. Sometimes that’s the only way to bleed some clutch hydraulic systems.
