what’s the best transmission oil to use
Thanks
Just go to the Honda dealer and buy it there. That will solve the problem.
+1…Honda transmissions are notoriously finicky if you don’t use the correct fluid
+1 to both answers. I owned a 2000 Honda S2000. I used Mobil 1 oil and rear differential fluid but Honda transmission fluid purchased fom the Honda dealer. The transmissions are very, very good. The rear differential, not so much. Change the rear differential fluid EVERY 30,000 miles.
