My 2002 Focus IB5 transmission has a bad halfshaft on drivers side. How is the shaft removed from the transmission? The manual shows some special tools, others say to pry it out. I have had no luck with this. I think there is a c ring holding it, how is it released?
Related topics
| How to pull the drive axle from the transmission | 8 | 2730 | June 19, 2010 | |
| Trying to remove CV shaft. Part remains stuck in the transmission | 21 | 37203 | June 30, 2020 | |
| What exactly holds a drive shaft into a FWD transmission, and how to properly reinstall? | 57 | 1001 | May 20, 2025 | |
| Advice on cv axle half shaft replacement | 9 | 4791 | December 31, 2017 | |
| 1993 Escort LH CV stuck fast | 2 | 389 | April 24, 2008 |
