Audi 2002 TT headlight bulb replacement
What do I have to remove to replace the low beam halogen headlight bulb? How hard is this? Do I need any special tools? About how long will it take? Thanks.
There may be instructions in the owner’s manual. If not, the Haynes manuals will show you how. The parts stores mostly don’t mind the customers looking in them.
If it’s a standard bulb you normally remove and replace them from the rear of the headlight assembly. Some vehicles have little clearance in which to work, and other things need to be removed for access to the bulbs.
Check the owner’s manual for information about bulb replacement, and lots of other good information, too.
