I have a 1993 Toyota Camry and it had an aftermarket ASC sunroof installed before I purchased the car. I did not get a manual for the sunroof with the car.
I recently had a main seal leaking where the transmission/torque converter connects to motor. Local transmission shop corrected this problem. In doing so, they disconnected the battery.
I am fairly sure this cause an issue with the sunroof and it needs reset or programmed. The button for the sunroof marked ‘ASC’ is a constant red instead of the normal green before I had the car worked on. No buttons respond. I have searched the web for a manual or instructions with no success.
Does anyone have any info or instructions to reset?
Any help would be appreciated.
Thanks, Mike
Is the place that did the installation still in business? Perhaps they could help.
