where is the best place to get step by step instrutions on changing my antenna. It’s in my trunk but behind the lining material. i tried at the library to no avail.
You are only going to get that kind of detail in the factory service manual or possibly Alldata. That’s why I always get the factory manual for any cars I have even though they cost $100-200. Sometimes you can get one on EBay for a lot less but they call Haynes etc. factory manuals which they are not.
It should be fairly straight forward though once you remove the side panels. It should just unscrew from underneath. Possibly the dealer would let you look at their manual if you buy the antenna from them, or if you have a relationship with a shop that subscribes to Alldata, they might print that part out for you.
