the antenna broke off and left a portion of the threads in the antenna ‘housing’ located on the fender. how do I get the ‘housing’ off the fender so it can be replaced?
The base should also be accessible after removing the inner wheel well cover.
Unless they’ve changed over the years (likely have) there will be a lock nut on the bottom side.
