My '01 Alero has started making a tica-tica-tica noise in the dash in the area of the flasher switch. The noise comes and goes but does stop whenever I activate the flasher or the turn signal. Is there an easy fix here?
Is that noise anywhere around where the heater blower may be located?
As this was posted over a year ago, I am sure you have had this problem fixed by now. However, if you haven’t, the same thing happened in my Alero, I thought it was the blinker but it isn’t. It has something to do with the computer in the car and if you don’t get it fixed (I was told) it could cause a major malfunction. Cost be a couple hundred.
