Hey guys! First off, sorry for being a n00b. I have an 01 Alero that is a great little car with only 80k on it. Runs and drives like a champ but it has 2 issues that drive me nuts. The AC doesn’t work at all. If you press the button on the dash, it does not light up. The compressor doesn’t do anything either. I did check all the fuses trying to eliminate the simple but I didn’t find any bad ones. What would be my next thing to check? Is it ever the AC relay?
Then the one that really frustrates me: the rear defrost. I live in MI, so 75% of the morning I need it to clear either snow, ice or fog. The button works but the lines don’t heat up. I checked them all for power and none have power. I also checked each one for breakage and continuity and they are fine. I saw somewhere that the connection at the module likes to fry but I inspected it and didn’t see anything burned. Does anyone know where to go from here?
Thanks guys!
