I have a 2007 Acura TL and can’t find the service codes on line. Does anyone know where I can find the list of service codes for it? Specifically, I am getting the code B15, getting that one would be a good start.
Service B:
Replace engine oil and oil filter
Inspect front and rear brakes
Check parking brake adjustment
Inspect tie rod ends, steering gear box, and boots
Inspect suspension components
Inspect driveshaft boots
Inspect brake hoses and line (including ABS)
Inspect all fluid levels and condition of fluids
Inspect exhaust system
Inspect fuel lines and connections
Service 1:
Rotate tires
Service 5:
Replace engine coolant.
You can find more by inputting your vehicle at owners.acura.com
thanks for the info, did you find that online? Or, is that in a manual?
Looks like the letters and numbers mean something by themselves, the B the one and the 5?
Yep. You’re getting 3 service codes, not 1.
That list (and all the other code lists) were found at owners.acura.com
