I have a 2012 Nissan 370Z about 60k miles with an A/T that makes a single click noise when switching from park, drive, reverse, or when changing gears while driving. Is this normal? If not, what could be the issue?
Not normal, may be a failing U-joint (or CV joint) in the driveshaft
