Hi, today in the Contour, making a right or left turn, feel some sort of movement under my feet. Should I be worried or not. This is common in older cars.
I’m pretty sure I haven’t felt this in the past, but today definitely some kind of movement.
Somebody should check the steering rack to see if it came loose. If you can feel something move, an alignment shop can find the cause. This isn’t common on older cars, it’s common to broken or worn out parts.
[quote/]Should I be worried or not. This is common in older cars.[/quote]That’s true. I drive older cars, and I’m worried most of the time.
Seriously, pdv has no doubt nailed it. The rack is flopping around.
Should I just go to the dealership or something like firestone or farm and fleet
