98 Buick Park Ave cabin air filter location
Where’s the cabin air filter located at?
Are you sure there is one??
There’s three cabin filters in your vehicle.
Remove the insulator panel from under the left side of the dash.
To the right of the gas pedal you’ll see the filter cover. Push down on the filter cover and remove.
Remove the tape from the first filter and pull out the filter by pulling the tab.
Remove the tape from the second filter and remove the filter by pulling the tab
Remove the third filter by pulling the tab.
