Anybody know where the fuse is for the power door locks on a 93 Bonneville? The fuse blocks under the dash beside the steering column, and under the hood against the firewall are apparently not it. Thanks!
There’s two fuses used in the door lock circuit.
Fuse 15, 15 amp, instrument fuse panel, left side of instrument panel.
Fuse 3, 15 amp, relay center, right side of instrument panel.
Thanks!!
