I have spark, I did a tune up replaceing the spark plugs,cap,rotor,points and condenser. When I try to start it fuel is pouring out the top of carb and its trying to start but just wont run. !!!please help!!!
Sounds like a bad float or stuck needle valve in carb, A remote possibility is a fuel pump putting out way too much pressure.The brass floats can have a hole in them and fill up with gas, the neophrene ones can absorb gas over a period of time and become to heavy, or your float or needle valve could be stuck.
And tapping on the carburator with a hammer handle will sometimes get a float unstuck. But the carburator requires rebuiding when this starts happening
