car siezed operation,thought timming belt,decied to look elsewere first,checked fuses,all good,switched out ignition relay with horn relay,car started,once!have to pull relay as if to reset something each time…what is my question???any help thankful
There may be an issue with the security system.
I don;t know what your question either.
I thought the timming belt may have broke,in hopes of it being something else i looked at fuses,and relays,switched relay out for ignition,car started,only once,had to pull relay again ,and it sounded as if primeing,put relay back in ,car started,i need this car for work transportation,wondering if any one is familiar with this,is it possible this is resetting some thing?
