rear brakes make a noise in reverse, only 43,000.ml
The rear brakes need a visual inspection. Some vehicle’s drum brakes self-adjust when braking while backing up, don’t know if that applies to your vehicle or not though. The symptom does sort of seem like a problem with the brake adjustment mechanism, or the emergency brake function. Does the noise occur in reverse even when you aren’t braking?
