2018 Honda CR-V - Brake failure
The title to this tread should really read “Dead Battery”.
With many late model vehicles, if the engine will not start and you deplete the vacuum in the power brake booster you will get a brake warning message, it is not the cause of the problem. After the engine is started, vacuum is restored and the message goes away.
