Motor oil leaking from oil filter housing dripping to ground
That might be normal if the oil and filter was recently changed. If not, the oil filter or its seal may be leaking. Not good. In any event, suggest to monitor the engine oil level on the dipstick frequently, so you can always keep it topped off at the correct level. If the oil filter is actually leaking, that’s an emergency situation and needs to be looked at by a shop asap.
If it is a 3.6l V6 then this is a very common problem with the OEM plastic filter housing, aftermarket replacements are better designed…
Mopar may have an updated one by now…
Features:
- Upgraded replacement - this aluminum oil filter housing is specially designed to more reliably replace the failure-prone plastic housing on specific Chrysler, Dodge, Jeep and Ram vehicles
- Repair it once - don’t fix a leaking filter housing with another failure-prone design just like it; repair it right the first time with this improved design and don’t worry about it again
- Made in USA - engineered and manufactured in the United States, and backed by a team of product experts with more than a century of automotive experience
- Smart solution - includes high-pressure, die-cast metal housing and all required gaskets for a robust repair of the component that causes leaks
