slack in trans when taking off. some times car loses power.
Does your Veloster have one of the legendary Hyundai dual-clutch automatics? If so, get it into the dealer’s shop and start saving all your receipts. Here’s why.
If you bought it new you have a 10 yr,/100k powertrain warranty. Even if you bought it used you should have the balance of 5 yr./60k. Regardless, check the transmission fluid and make sure it’s at the right level and isn’t burnt. If it’s beyond the warranty take it to a good independent transmission shop.
