I have followed the manufacturers schedule for maintenance. car runs great and has 35000 miles. next maintenance charge is $750. Is it necessary to pay that much or should I find a good mechanic that can do the same check hopefully for less.
I think that this is too easy to answer . Of course you can have any place do the service , just keep your invoice .
You need to find a good independent mechanic after the warranty run’s out plus it should be quite a bit cheaper.
