I would have thought so, but RockAuto lists different studs for the front vs. rear of the Accord, but the same studs all around for the Crosstour (the ones for the front of the Accord). Odd.
“Shortly”?
This vehicle is now 8 years old, and several ham-handed people could have overtightened the lug nuts over that period of time.
That is True
Yep just seems they were better metal back in the 60’s or so
I was thinking back in the 60 70’s
This isn’t the 60’s/70’s.
Yep
Not sure how to ask anyone that touches the tire lugs
What is your air wrench set at
And when was it tested last ??
Just thought I would ask the question
Great answers
I don’t use an air wrench.
I use a battery operated impact gun.
There is no setting on the battery operated impact gun.
There’s no reason to have the battery operated impact gun tested.
I use the impact gun to quickly run down the lug nuts, but not tighten them.
I then follow up with the torque wrench, and tighten the lug nuts to manufacturer’s specifications.
Regrettably, for sure!
tex:
Well, I don’t know what Rock Auto is on about, and they seem trustworthy to me, but I just went out and successfully switched two lugnuts from front to rear on my 2010 Accord.
Personally I wouldn’t trust anything I hear or read on line as far as I could throw it.
It’s the studs they list as different. Maybe different where they attach? Or just an error in the listing.
The difference between front and rear wheel studs, at least in modern vehicles (exceptions to every rule), is the thickness of the hub and rotor and or drum hat thickness… So typically front are longer than rear wheel studs, the knurl may be different also depending on the thickness of the hub… Lug nuts are the same front to rear… Again exceptions to every rule…
I was at the local gm dealership and the service advisor was telling the guy to go to a parts store etc. because the 2 piece lugnuts were $35 each. can anyone clarify?
Probably much less expensive at the parts store compared to the dealership parts counter.
I didn;'t even know you could replace the studs individually. I always thought they were welded to the wheel hub.
I also don’t see what the issue is here if they needed to replace just one then just replace that, why replace all 5 and do more work.
The issue is that once you get to the point where you can replace the stud, it isn’t much work to replace them all, but it is a lot of work to get to that point. Doing it a second time can be quite a pain, and if you are paying someone else to do it …
Yes, they are that expensive.
For $35 you can buy and entire set of one piece chrome lugnuts and never have the problem again.
Exactly. Also, there’s the possibility that whatever led to that first stud breaking, like overuse of an impact wrench, could well have happened to the other 4.
Because if I’m going to remove the brake caliper, pads, mounting bracket, rotor, and possibly a dust shield, I might as well spend another 2 minutes replacing all the studs on that hub and start fresh.
Yes the OEM honda lugnuts are very expensive. I needed four and the parts guy gave it to me lol.
I think they run $20 each.
