2015 Chevrolet Traverse - Tire scrub?
when I turn right or left it sounds like the tire touches plastic, front and back, when I go straight, it runs very well without noisy.
I guess this post is from the carcomplaints web site . Find a local tire shop as you might have the wrong size tires . On the drivers door jamb you should have a plaque that says tire size and tire pressure . You might read that and check the tires yourself. Other than that you need a shop to see what is wrong before you have a real problem.
If the tires are the correct size, as mentioned above, then it sounds like your inner fender splash shield(s) has come loose and your tire is rubbing it when turning either way… If you are unable to look for the problem, then take it to a shop and they should be able to find the issue for you…
