2015 Chevrolet Equinox - Stabilitrack warning
abs …service stabilitrack light
Well, you are likely due for your second brake fluid flush, have it serviced at the same time.
My 07 has stabilitrak warning too. 2-3 days. No light. Downhill braking and turning makes it come on, sometimes. Guess gm never has figured it out.
Seems pretty clear that it needs service it. Get on that.
You did not ask a question . It seems pretty clear that you need to service something that is causing that message .
If the ABS light is on, the stabilitrack light will also turn on.
The stabilitrack system uses the ABS to function.
No, I have a clue about the system but you posted FOUR words with no other info about the vehicle. Not even a question. What is your question?
it comes on it gose offf been off for two days now so what do ya think??
In a message dated 12/4/2022 7:18:12 PM Eastern Standard Time, notifications@cartalk.discoursemail.com writes:
yes sir i know but it comes on and it gose off been off for two days now im clueless as to what its problem is
again its on then its off been off for two days now so im clueless as to whats up with it
In a message dated 12/4/2022 7:17:18 PM Eastern Standard Time, notifications@cartalk.discoursemail.com writes:
lol we dont have hills here but thanks for your input all is welcome
In a message dated 12/4/2022 6:37:25 PM Eastern Standard Time, notifications@cartalk.discoursemail.com writes:
It is possibly a bad or dirty wheel speed sensor.
Chevy Service StabiliTrak Warning Message (youcanic.com)
PIC5428G Chevrolet Technical Service Bulletin (tsbsearch.com)
You need to have the error codes checked to see what is stored. This takes more than a cheap code reader or one the auto parts store uses.
If you also are getting an ABS light at the same time, I’d suspect a wheel speed sensor but if not I’d suspect a steering sensor. There are 4 wheel speed sensors, one steering sensor and an accelerometer sensor. Any one of them could cause an intermittant problem. There are 6 or 8 hydraulic valves that could be sticking. But the error codes will help direct you to the source.
That’s why we have these people called “automotive technicians”. And a lot of them are actually pretty good figuring out these problems that have us mere mortals baffled. Maybe you should try one.
My code said RF speed sensor circuit. Changed wheel bearing and no success. Still get stabilitrak warning every 3-4 days. Some days I get no error. Some days I do. A person might change harness going to RF wheel. As it’s 24” long and easy to change.
