Nissan Rogue 2013 runs rough whe waiting at light. Sounds like it will stall, but doesn’t I tried fuel injection cleaner
Is all the routine engine maintenance up to date? Spark plugs and the like?
Hi! Yes, it has been serviced for that. Thank you for your information. I am taking it in on Monday to have it looked at.
Since the service is up to date, I concur the throttle body idea above is where to start, absent any stored diagnostic codes. That part can gum up over time and the throttle valve begins to stick rather than move freely, causing this symptom.
