Yesterday, my windows worked, and I parked the car and put them up and went into a store, came back out 10 minutes later and my windows won’t work. The front passenger window works only from the passenger control. The driver control will not open any of the windows including the passenger window. I had the fuses checked and the fuses are all fine. The other windows don’t work from their controls, meaning the Back drivers side and the passenger side windows don’t work at all. This is extremely frustrating since the air conditioner stopped working and stops working every single time the defrost is used. This car has had one problem after the other, all which seem to be consistent with other 2013 ford edge owners problems.
D you have a lock button on the on the driver control that prevent’s the other’s from working when engaged?
