My drivers side window is stuck open, my passenger side window is stuck closed. I don’t hear any noise when I press the button (no motor running). The window that is stuck closed, worked once this winter when it was around 20 degrees outside. But since then it will not work. Could this be a fuse?
Sure, it could be a fuse, but not if the back ones work and the fronts don’t. It’s more likely to be switch(es), motor(s), or regulator(s) in that order.
