2013 Ford Edge windows quit working
All windows quit working
The windows don’t work from the drivers window console only, or do they not work from each door switch too? It might be a fuse. Check the fuse box inside the car and under the hood. There is a diagram on the fuse box cover that tells you what the fuses control. If it’s not in the first box, it will be in the second. That’s the cheap fix.
The first component that directs power to the power windows is the BCM.
