The driver’s window wouldn’t open and other window’s wouldn’t open from driver’s door but would open from each door. After trying all buttons (including window lock button) now none of the windows open.
Check the appropriate fuse. If that is O.K., start with the driver door switch and then check the wiring from that switch to the module that controls the windows. What vehicle is this anyway?
