Rear door lift function has failed on my Limited model Highlander. What to expect for cost to fix and best place to get the repair?
Thanks for the answer. You are right, the question was poorly designed. I will have the dealer give an estimate. THANKS
Thanks for the information, it could well be the remedy. I don’t use the lift function anyway, but now the gate won’t stay open and slams shut. Thanks again
Are saying you have a power lift gate but you don’t use it ? Why ?
I think nevada has given you the answer to your problem .
Thanks for the tip! My wife does use the lift function, so the previous answer does appear correct. THANKS
