my car leaks on passenger side
Is it leaking inside the car, or in the area of the engine compartment, or is it leaking in a different place?
What color is the leaking fluid?
Does it have an odor?
There is an ac drain tube that if plugged can cause that issue. Tis site may be of help G35-G37 Water leaks - probable cause and solution - G35Driver - Infiniti G35 & G37 Forum Discussion
Without question, that can be a source of a leak, but–2 days later–the OP has still not told us where it is leaking, or whether the leaked fluid has a color and/or an odor.
