2013 Infiniti G37 Sedan - AC leak
I install freon it goes into car fine but it is coming out somewhere because by time I nstall a can of freon it shows empty again but don`t see or hear no leaks what can this be?
Time for a AC professional to look at the system.
R134a is a colorless, odorless gas basically, you are going to have to use an electronic sniffer or add AC dye in order to find your leak…
Best to take it to a Pro AC repair shop…
You answered your own question…
But that does not mean there isn’t a leak. refrigerant is colorless and oderless. If you install dye into the system and check for leaks with a black light, you might find the source.
Or take it to a professional that has the correct equipment to find and fix the leak and properly recharge it.
edit: Seems we have a consensus… :man_mechanic:
