leakage problem after heavy rain results in mats on driver’s side-front & back- becoming saturated in 2007 Infinity G35x. Possibly, sunroof drainage tubes may be blocked. Not sure of tube location.
Google is your friend as there are many videos showing how it is done . Usually just using trimmer plastic wire will work . You should see the drain holes just by opening the roof and looking in the channels.
