2012 Chrysler 200S convertible top wont go down. Need some help please its my dads only true love!
Blown fuse or bad switch is pretty likely the cause. A good independent auto repair shop should be able to handle it.
Thank you, will check it out.
Make sure the trunk partion is in the correct spot. Also, be sure and look in the owners manual or Google to make sure you are following the correct procedure if this isn’t a car you usually drive.
