intermittent traction control, stability control, antilock brake lights warning with no pattern sometimes they stay off for days sometimes stay on for days.
Good to know. Now, is there an actual question ? After all this is the “ask someone” section.
I presume your question is, “What’s wrong with my vehicle?” More than likely there’s a malfunction in the abs. You can drive it with the warning light(s) on but it’s better to get the problem fixed. You might have low brake fluid, you might have a bad wheel speed sensor, you might have a bad abs unit. None of us can tell from wherever we are but a good mechanic can.
